Activity Forums Adobe After Effects Expressions Display random keyframes
  • Display random keyframes
    Posted by Stacy Bias on September 29, 2017 at 5:26 pm
    Hi all!
    As may be clear from the asking of this question, I’m fairly new to AE. I want to create a bit of a stop motion/paper cut vibe to a project I’m working on. One of the elements is a campfire. I have about 15 hand-drawn flames. Here’s what I want to do:
    I want to put each one on a single keyframe in a pre-comp and then I want to loop it — but I want the loop to choose keyframes randomly so it’s not always the same flicker. I am 10,000% positive this has been covered before but I think I’m not searching the right terms. Ideas? Thanks kindly!
    Stacy Bias replied 8 years, 11 months ago 2 Members · 2 Replies
  • Dan Ebberts
    September 29, 2017 at 5:59 pm
    I can’t tell if this is what you’re after, but it might get you started. Iimport your drawings as an image sequence, add the sequence as a layer, turn on time-remapping, and add this time remapping expression:
    n = 15; // number of frames
    framesToTime(Math.floor(random(n)))
    Dan
  • Stacy Bias
    September 29, 2017 at 6:29 pm
    Oooh! That sounds like it’ll work! I’m off for the weekend now but will give it a go on monday. Thanks so much for such a quick and helpful response!
