Activity › Forums › DaVinci Resolve › Display monitor update
  • Display monitor update
    Posted by Andrew Smith on February 2, 2012 at 2:53 pm
    Hello
    I am updating my home setup this weekend and would like to get some quick advice. I use a Dreamcolor/VT25 calibrated setup but for my computer monitors I use really old Apple Cinema Display 23″ silver and white monitors.
    I would like to update the pair of monitors with something excellent that I can have a lot of control over light spill suppression, color, adjusting height, etc.
    if you were to chose from this selection any advice??
    https://www.bhphotovideo.com/c/search?Ns=p_REVIEWS|1&ci=6559&N=4294542210+4294949064&srtclk=sort
    Kevin Cannon replied 14 years, 7 months ago 2 Members · 1 Reply
  • Kevin Cannon
    February 4, 2012 at 9:04 am
    I got the LP2475w so it would match the bevel of the Dreamcolor… so whatever that’s worth. The stand is about identical in terms of height and adjustments, which I always thought was pretty good. I think the cheaper HP looks like it has about the same bevel with a different stand. The backlight adjustment is good but can only go so far – I still find it a bit bright vs. projection, so I’m adding a glare reducing filter to cut some light.
    KC
    Prehistoric Digital
    PhD Grading Suite
