Activity Forums Maxon Cinema 4D Display in Editor Window
  • Display in Editor Window
    Posted by Yoondo on February 23, 2007 at 6:17 am
    Hi folks,
    I have baked a room with the bake object under render.
    Everything came out just fine and it only takes 2 secs to render instead of 10 minutes.
    Now, the problem is that the display in the editor window is just white, but when I click
    render it’s fine. I messed around with display options but no luck.
    This is probably something so simple, but I must be missing out on it.
    Anyone with a answer would be appreciated.
    Mylenium replied 19 years, 6 months ago 2 Members · 1 Reply
  • Mylenium
    February 23, 2007 at 6:38 pm
    Mmh, what part of the shading did you actually bake?
    Mylenium
    [Pour Myl
