Activity Forums Adobe After Effects displacing a layer
  • displacing a layer
    Posted by Accountclosedduetonorealnameused on January 16, 2007 at 11:01 pm
    I can displace a layer based on a luminance map, using “Displacement Map” filter
    But this only allows me to displace X and Y.
    I want to displace scale based on the luminance mpa.
    Can AE do this?
    workaround?
    the scale “ramp up” needs to be smooth, so I must use a disp. map.
    thanks!
    Iancorey replied 19 years, 7 months ago 2 Members · 1 Reply
  • Iancorey
    January 17, 2007 at 12:02 am
    Use your luminance matte as a track matte for an adjustment layer with the Transform effect on it. Use the scale on the Transform effect.
    I only “think” this will work.
