Activity Forums Adobe After Effects Displacement Maps Problem
  • Displacement Maps Problem
    Posted by Glenn l Smith on September 3, 2012 at 5:07 pm
    Hi all,
    I’m using a photoshop drawn displacement map to move a close up picture of someones face, almost creating the sense that it is 3d. The problem is whenever I import the image of the face, then the displacement map of the face that i’ve made in photoshop, it ends up being in the wrong place once I put the displacement map effect on.
    I have the right layer selected and it set to luminance but every time the displacement map is off to one side of her face instead centered. Even if I move the displacement map layer in after effects so it lines up with her face perfectly it still will not seem to work.
    Any idea what I’m doing wrong or know a better way of creating this effect? Its pretty much like the effect from the Kony 2012 video like this https://vimeo.com/38726389
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Chris Brett replied 13 years, 11 months ago 6 Members · 12 Replies
  • 12 Replies
  • Erik Waluska
    September 3, 2012 at 5:41 pm
    Check that your displacement image and the image of the face are the same size and that the “displacement map behavior” option is set to “center map”. However, I’m not sure the displacement map effect will work for the effect you’re trying to achieve.
    FreeForm is good for that type of effect because it’s a mesh warp effect rather than just a displacement of pixels to fake distortion. It’s not included with AE, you have to purchase it, but the standard version isn’t too expensive. HTH
  • Glenn l Smith
    September 3, 2012 at 5:49 pm
    Yeah had both images the same size and those settings set, but still couldn’t get it aligned. I’ve done it successfully on a single clip which made the face move very slightly which is what I need, just so it makes people feel the illusion of 3D. The problem is the displacement layer seems to have a mind of its own so only aligns on some pictures. I must be doing something wrong on import i think…
  • Tudor “ted” jelescu
    September 3, 2012 at 7:00 pm
    Precompose the displacement map layer and use the precomp. This way you can tweak the alignment of your displacement map.
    For true 3d displacement Free Form can help, or even better FreeForm Pro.
    Here’s a tutorial on 3d displacement using Free Form:
    https://library.creativecow.net/jelescu_tudor/3D-from-2D-image_AE/1
    Here’s an example of displacement and animation on photos using FreeForm Pro:
    https://www.youtube.com/watch?v=BphBKInCXvI
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Chris Brett
    September 3, 2012 at 7:06 pm
    Hi Glenn
    I might be missing the point here or stating the obvious but the main 3D effect on the Joseph Kony edit is achieved by multi-planeing a few cutouts.
    I’m fairly new to this platform so sometimes I get my terminology wires crossed but displacement mapping in my experience usually means a ‘fake’ 3D effect applied to a 2D image using a continuous tone black and white source as a reference ( very good for water effects )
    If its the multi-plane effect you want just import the PS file as cut outs on different layers / arrange them in 3D space in AE / add camera / then animate camera.
    Theres plenty of good tutorials on this if you need them — all you need to do is checkout use of camera in AE on Andrew Devis’s stuff on this site / Video Copilot tutorials on their site or just surf Youtube
    —————– chris brett // uk
  • Jon Bagge
    September 4, 2012 at 12:57 am
    Generally you should have the displacement layer the same size as the image. As others have mentioned there are center/stretch options in the displace effect.
    One possibility is that you’ve imported the photoshop image as a composition with ‘retain layer size’. This will crop each layer to it’s bounding box, thus can make your displace map and your image different size even if they’re the same in photoshop.
    I did quite a big project recently using these techniques. Using displacement you can’t ‘rotate’ around very far, but adding other layers can help sell the effect.
    Here are some examples from my project. Most of them use flat layers, but the two portraits use displacement:
    3D still animation WIP from Jon Bagge on Vimeo.
    https://www.jonbagge.net
    Jon Bagge – Editor – London, UK
    Avid – FCP – After Effects
  • Glenn l Smith
    September 4, 2012 at 1:13 am
    Thanks for the help guys, think I got my head around the problem now!
    Thanks Ted, I’ll look into freeform it seems like a step up from what i’m doing at the moment.
    The displacement technicque we are using with the parallax effect in kony as well, as it adds a little bit more depth and tricks your eyes into thinking its super slow motion camera. Got it looking pretty good so far!
    Those animations are amazing Jon, great job! Its pretty much the same as the effect we are going for too!
  • John Cuevas
    September 4, 2012 at 2:21 am
    That was some great work Jon, very impressive(made me cringe a bit thinking of the time it took), really appreciate that you shared that with us.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Chris Brett
    September 4, 2012 at 8:34 am
    Hi….
    ….slightly off-topic addition but does anyone know why I’m getting a line of html code instead of a link to Jons work please ?
    What I see is a time-line slider of the type that sits below a streaming video and a line of code like this above it —
    Also can I use this code as a link in some way — not working for me so far …. atm am totally puzzled by this
    Chris Brett // uk
  • Jon Bagge
    September 4, 2012 at 10:32 am
    It’s weird. When I posted it yesterday it looked fine to me, but now my post has code instead of the embedded video.
    You’re quote of my post though has the embed working..
  • Chris Brett
    September 4, 2012 at 2:26 pm
    Hi Jon
    Yes odd …. I reckon its a one-off …. a corrupted file on the Creative Cow server or something ….. anyway been able to access the work now and very nice too – also your main reel.
    BTW – if you dont mind commenting was wondering if you generated the sparkle on the words ‘Merry Christmas’ with Particular or by some other method.
    All the best
    Chris Brett
