Activity Forums Adobe After Effects Displacement Map…please Help!
  • Displacement Map…please Help!
    Posted by Simka Cvetkovic on February 1, 2007 at 8:53 pm
    Hi there.I have a problem.Recently I had to re-install my After Effects 7 (I had a few problems with my OS).Now everything works fine,there is only one thing.I can’t find effect Displacement Map.I am trying to follow some online tutorials and one of the steps is to apply Displacement Map(Effect>Distort>Displacement Map).I’m sure that I had it before reinstalation but now is gone.Can you help me out please?I’m trying to serach my plugin collection bet there is no results.
    Thank you!
    Simka Cvetkovic replied 19 years, 7 months ago 3 Members · 6 Replies
  • Mark
    February 1, 2007 at 9:29 pm
    Use the effects and presets window and type in displacement map, see if it comes up. It would be wierd if it didn’t, as this is a standard filter with the professional version of AE.
    Mark
  • Simka Cvetkovic
    February 1, 2007 at 9:34 pm
    Nothnig…its not there.I’ve got only Advanced Displacement,nothing else.
  • Simka Cvetkovic
    February 1, 2007 at 9:40 pm
    No,there is no such a thing.I’ve got only Advanced Displacement and nothing else.
  • David Bogie
    February 1, 2007 at 10:35 pm
    About all you can do is reinstall. You installed the non-pro, standard version of After Effects. If you look around, you should see you are missing lots of pro-only effects.
    bogiesan
  • Simka Cvetkovic
    February 1, 2007 at 10:51 pm
    Thank you very much for your answer.The only thing I don’t understand is,before reinstalation OS and After Effects I had Displacement map effect.But,when I installed AE7 again Displacement Map was gone.After Effects installation was the same like the first time.The same CD I’ve used to reinstall.I have only one CD.I hope you understand what I mean (sorry for my english).Is there any way to install those “pro” effects?
    Thank you very much!
  • Simka Cvetkovic
    February 2, 2007 at 8:27 pm
    Thank you very much for your time and all the answers!
