Activity › Forums › Adobe After Effects › displacement map won’t tile
  • displacement map won’t tile
    Posted by 8i8-8i8 on July 13, 2006 at 2:19 am
    hi experts,
    i’ve got a problem with displacement map.
    i’ve got a bigger image with the effect applied to it, and a smaller image for the map which i’d like to repeat a few times.
    YES i’ve precomposed, and YES i can see the displacement, but my problem is that changing between center map, stretch map and tile map doesn’t seem to change ANYTHING!!!! it’s always just the small portion in the center.
    what am i doing wrong?!
    many thanx
    8i8
    (using AE 6.5 on mac)
    8i8-8i8 replied 20 years, 2 months ago 2 Members · 2 Replies
  • Ryan Hill
    July 13, 2006 at 3:15 pm
    When you pre-comped, are you sure you made the composition the size of the image, rather than the size of the containing composition?
  • 8i8-8i8 Create COW Profile Image
    8i8-8i8
    July 14, 2006 at 7:28 am
    thanx robothero, you’ve made my day…
    i was pre-composing from within the same comp i was trying to displace,,,, duh…
