Activity Forums Maxon Cinema 4D displacement map to wireframe mesh ?
  • displacement map to wireframe mesh ?
    Posted by Frank-edouard Wozniak on May 18, 2010 at 8:35 am
    hi all you creative geniuses…
    i’m new to displacement maps on c4d
    i would like to apply a displacement map to a surface mesh because my final render will be in wireframe…
    is there a way to convert my displacement map to become a wireframe mesh ?
    merci beaucoup !!
    f e w
    Kenneth Kirkpatrick replied 16 years, 3 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    May 18, 2010 at 12:00 pm
    If you have MoGraph you can use the Displace Object and make it editable. If you don’t have Mograph but your object is planar you can do the same thing with the relief object.
    But why do you want to bake the displacement into the mesh?
  • Frank-edouard Wozniak
    May 18, 2010 at 12:06 pm
    you are right adam… no need to bake… in my case the solution was to use the mograph displace object… that i found very useful and powerful..
    merci beaucoup…
    f e w
  • Kenneth Kirkpatrick
    June 10, 2010 at 11:04 pm
    I myself have had occasions where I would have liked to be able to bake the displacement into the mesh. If a displaced object was close enough to other mesh where there was a possibility of overlap, I would have used this option were it available, so I could see the distance between the objects without waintin for a displacement render.
