Activity › Forums › Adobe After Effects › Displacement map problems
  • Displacement map problems
    Posted by Shane Benson on April 24, 2009 at 7:14 pm
    Ive rendered out a black and white alpha pass of a 3D mesh outof Cinema 4D. The pass is a object buffer which is just a basic black and white alpha channel pass.
    I want that alpha pass to displace the footage I have below it. I have everything set up and its displacing the footage, however im having trouble with the sides, top and bottom of the footage. No matter what settings I use, the main footage is moved by the displacement map causing the sides to be black. Its almost as if ive moved the footage over out of the view.
    I have a basic understand of how displacement maps work, but I am not sure how to correct this problem. I know that 50% gray will not displace, but the alpha pass I have is solid black, with white and gray areas.
    Any idea?
    Shane
    Tony Silva replied 17 years, 5 months ago 2 Members · 4 Replies
  • Tony Silva
    April 24, 2009 at 8:02 pm
    I’m not sure if your alpha has any greys in it, but displacemnt maps needs shades of grey to look good.
    black will displace 0%
    white will displace 100%
    the greys inbetween smooth out the displacement.
  • Shane Benson
    April 24, 2009 at 8:17 pm
    Ok, then I guess ill have to do this in 2 parts.
    The first part will have the black/white alpha, because I need that for the track matte.
    The second part, ill have to replace the black with 50% gray, and use that for the displacement.
    Or better yet, is there a way to add displacement to areas that only show by the track matte?
  • Shane Benson
    April 24, 2009 at 8:34 pm
    Hey! That worked! Thanks!
  • Tony Silva
    April 27, 2009 at 3:48 pm
    nope, not sure at all…
