Activity Forums Adobe After Effects Displacement map noisy edges
  • Displacement map noisy edges
    Posted by Terry Hahin on May 19, 2010 at 10:41 pm
    Hello,
    I haven’t seen this before but I don’t use displacement mapping too much. I’m getting some pretty dirty edges when I do a displacement map on an vector image (from illustrator).
    It’s a pretty basic text element on top of a silk backdrop. Displacement map applied to make the movement of the silk apply to the text on top. Problem is….the displacement map dirties up the edges of the text pretty bad.
    The text begins to essentially break down around 15 pixels of displacement. Any thoughts on this?
    Terry Hahin replied 16 years, 3 months ago 2 Members · 2 Replies
  • Kevin Camp
    May 20, 2010 at 2:39 am
    you could try working in a higher bit depth. the greater the bit depth, then greater the levels of colors/lightness that you’ll have to generate the distortion, so that should produce smoother results.
    if you silk footage is at a lower bit (say it’s 8-bpc, and you set ae to work in 16-bpc) then you’ll need to add a little blur to the footage (precomp the footage and use a blur effect, then use the precomp as the displacement map). this will produce greater levels of color, otherwise you will still get the lower bit depth issues.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Terry Hahin
    May 20, 2010 at 2:47 pm
    Thanks Kevin,
    this works great. Your advice is always very helpful.
    Cheers!
    Terry Hahin
    Designer and Editor
    terryhahin.com
