Activity Forums Adobe After Effects Displacement Map Issue
  • Displacement Map Issue
    Posted by Cameron on December 21, 2005 at 11:57 pm
    I’m creating the effect where text is projected onto the surface of a face and then animates across the facial contours. I took the photo of the face and made it greyscale and adjusted the contrast of it to use as the displacement map for the original photo. When I take the text (an illustrator cs logo) and apply the dirplacemnt map to the logo it displaces fine. My issue is when I animate the posiiton of the text across the surface of the face, the displacing does not update. What do I need to do to show the updated displacment? Thanks!
    Aharon Rabinowitz replied 20 years, 8 months ago 4 Members · 3 Replies
  • Colin Braley
    December 22, 2005 at 12:50 am
    Well think about AE’s default rendering order. Masks, then effects, then transforms, then blend modes. What I suggest is doing the animation of the position of the logo in a precomp, then displacing that precomp.
    ~Colin
  • Sascha1979
    December 22, 2005 at 10:47 am
    yes it will work in a precomp…
    another problem is that the text borders look very noise if i use the displacement map… is there any alternative to get a clearer displacement?
  • Aharon Rabinowitz
    December 23, 2005 at 3:27 pm
    instead of displacement map effect, try using the effect called caustics. You can soften the edges in that, and it does some really nice stuff, but it’s a lot more complex than the displacement map effect.
    Jim Tierney wrote a tutorial on it here:
    https://creativecow.net/articles/tierney_jim/caustics/index.html
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
