Activity Forums Adobe After Effects Displacement Map doesnt work well
  • Brendon Murphy
    October 16, 2017 at 6:15 pm
    Based on the description of what you want, you will need to create a separate texture for the displacement. For instance, you could:
    -create a new solid with a fractal noise effect on it
    -Set the noise type to “Block” and increase the contrast
    -Precompose the solid (Move all attributes”)
    -Choose the precomp as your displacement map layer
    -Where it says “Red” and “Green”, set both of those to “Luminance”.
    If you animate the evolution of your fractal noise, you should now see it affecting the text.
    Brendon Murphy
    ________________
    Visual Effects
    http://www.brendonmurphy.net
  • Brendon Murphy
    October 16, 2017 at 6:16 pm
    And actually, the featured tutorial on the homepage today covers this exact effect:
    https://library.creativecow.net/gleissenberger_tobias/adobe_after_effects_glitch_effects_no_plugins/1
    Brendon Murphy
    ________________
    Visual Effects
