Activity Forums Adobe After Effects Displacement map dirty
  • Displacement map dirty
    Posted by Wyatt on August 9, 2006 at 6:48 pm
    I am using a simple white logo over a water texture and the displacement map is totally pixelizing the logo. I converted the displacement layer to black and white and blurred it and still the logo is totally noisy and pixelized. Why?
    Wyatt replied 20 years, 1 month ago 2 Members · 2 Replies
  • Peter Litwinowicz
    August 10, 2006 at 5:24 pm
    I’m guessing you are having a problem for one or both of the following reasons:
    1) you need to be working in a 16 bit or floating point project. Many times an 8 bit displacement map does provide enough information to prevent aliasing (or what you call pixelized)
    2) AE’s displacement mapping does not provide any form of filtering. It just does a simple pixel “look up”. This is a know limition of AE’s displacement map filter. You should try our RE:Map product ( https://www.revisionfx.com/rmap.htm ). RE:Map has a displacement map filter that does the proper filtering. Like I suggested with AE’s displacement map filter, you’ll probably want to work in a 16 bit project.
    RE:Map also has a corner pinner that provides proper filtering (along with many other features that AE’s does not), a UV map filter (takes a rendered UV map from a 3D program and renders with any texture you provide) and an auto-distort plugin that distorts images based on their features.
    Cheers,
    Pete LItwinowicz
  • Wyatt
    August 12, 2006 at 4:18 am
    Thanks – 16bit was helpful and I am trying out the ReMap too.
