Activity Forums Adobe After Effects Expressions Displacement map / Camera
  • Displacement map / Camera
    Posted by Mathias Andersen on October 13, 2008 at 2:52 pm
    Hi fellow cow’s,
    Im not that in to expressions, trying too.
    My question for a expression goes like this
    I have pickwhip, the displacement map vertical/horozontial values to my null object, witch controll the camera’s x,y,z.
    thisComp.layer(“Dolly”).effect(“Separate XYZ Position”)(“X Position”)
    Where do i put a max value of 20′ to the displacement map value, or if I say that my camera’s max x-position is 300, then the value of displacemnt is 30
    Hope you understand
    Greetings from Denmark
    Darby Edelen replied 17 years, 10 months ago 2 Members · 2 Replies
  • Mathias Andersen
    October 13, 2008 at 3:30 pm
    Allright, Took my lazyness in hands and saw some expressions tutorials by Abraham – so found a durable solution.
    Mathias
  • Darby Edelen
    October 15, 2008 at 12:47 am
    Your solution will probably involve the linear() function or another form of interpolation. You can check those out in the AE help (F1).
    Darby Edelen
