Activity Forums Adobe After Effects Displacement effect
  • Chris Smith
    May 12, 2005 at 4:23 pm
    Having a hard time seeing what you speak of. Is it the Speed Vapor spot or the Ignite spot? The speed vapor spot had a section where it looks like the shoe is streaking in 3D space. Frame by frame shows that it is the outline of the shoe extruded, duplicated and then the duplicates are animated along a straight vector with motion blur on. Any 3D app will do this easily.
    If you mean the old streaky smear effect like the web page itself is simulating, you can get Pete’s Plug-ins. One of the plugs will do this:
    https://www.petewarden.com/
    Chris Smith
    https://www.sugarfilmproduction.com
  • Joseph Thomas
    May 13, 2005 at 10:23 am
    Chris,
    Actually it was the old streaky effect in the end! (with some tweaking). Still, it looks good. Thanks for your help.
    Joseph
