Activity Forums Maxon Cinema 4D Displacement and Bump channel?
  • Displacement and Bump channel?
    Posted by Hamid Rohi-bilverdy on June 8, 2010 at 4:26 pm
    Hi..
    I saw a couple of tutorials on how to create ripples on a surface just like when rain drops hit the water.
    The turorials I saw, was one with a displacement channel and another with a bump channel. What they have both of them, is that they want you to insert a emitter or a particle? I have set the my floor plane in at the object area and in the particles I have isues.
    I have created a text object. The text is above my floor plane, and my animation is that, my text submerges down under the plane, when it does that I want the ripples to take effect, but the “particles” tab wont accept my text, how can I make the ripples with my text going under the plane??
    Regards H
    Adam Trachtenberg replied 16 years, 3 months ago 3 Members · 4 Replies
  • Hamid Rohi-bilverdy
    June 9, 2010 at 3:42 pm
    please anyone…. I cant figure it out…
  • Adam Trachtenberg
    June 9, 2010 at 4:32 pm
    The ripple shader can only create round ripples based upon particle postion — not particle geometry. You would need a full-on liquid simulator like RealFlow for this.
    June 9, 2010 at 6:20 pm
    Hi Adam.
    Thanks for your reply.
    How do I get this full-on liquid simulator like RealFlow? Is it a third party plugin?
  • Adam Trachtenberg
    June 9, 2010 at 9:46 pm
    RealFlow is a separate application from NextLimit that has plugins for Cinema and other 3D packages. Unfortunately it costs thousands of dollars and takes quite some time to master. Blender is a free 3D application that has a liquid simulator available. I think there’s some way to get the output into Cinema but I don’t know how it’s done.
