Activity › Forums › Adobe After Effects › Disney Shadow Blend
Disney Shadow Blend
Posted by Ben Hale on December 16, 2009 at 4:42 amFirst time writing into the site.
I’m trying to import hand drawn animation into After Effects and achieve the soft shadow blur that Disney has on their characters. If I were to do it in Photoshop, I would use the wand tool to select the 2 colors next to each other, and with the selection it created, apply a blur filter.
I was wondering if there was any way to automate this in After Effects? How can I only apply a blur to 2 colors at a time?
Hope that makes sense. Thanks for the help.
Ben
Ben Hale replied 16 years, 9 months ago 3 Members · 9 Replies -
Anders Hattne
December 16, 2009 at 11:23 amUnfortunately I don’t understand what you want to achieve. Could you show some images of what you have and want to achieve?
Walter Soyka
December 16, 2009 at 12:43 pmTo build an effect like this, you want to create a new layer that contains only the two colors you’re looking for and blur them.
Try this: duplicate your footage, then add two Color Key effects (one for each of the colors you want to blur, the Invert Alpha preset, a Blur effect, and finally a Matte Choker effect (in that order) to the top layer. Adjust to suit. You may need to create an animated garbage masks to eliminate any unwanted blurring in areas of similar color.
The keys knock out the colors you want to blur, leaving only the colors you don’t. The Invert Alpha reverses that, so you keep the colors you want to blur, and knock out the rest. The blur is self-explanatory. The Matte Choker helps you tighten the blurred area, so it doesn’t overlap into outlines or areas of other other color.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Ben Hale
December 16, 2009 at 12:57 pm -
Walter Soyka
December 16, 2009 at 3:48 pmThis look is exactly what the technique I described above will do — though I’m sure there are other ways to accomplish this effect as well.
Once you get all the parameters in the ballpark for a good look for your footage, you can save the whole stack of effects as an animation preset. Then all you will have to do to re-use it is duplicate the layer for each set of colors you want to blend, apply your custom preset, and pick the new colors with the Color Keys’ pickers.
Walter Soyka
Ben Hale
December 16, 2009 at 6:05 pmDrop shadow or a black layer wouldn’t work because the shadow area would bleed outside of the circle.
Interesting, though, is that your black layer idea is exactly how they did it on Who Framed Roger Rabbit.
Thanks anyways,
Ben
Ben Hale
December 16, 2009 at 6:12 pmI’m excited about giving it a try. Thanks for explaining the Animation Presets too, I was weary of having to repeat the process for each pass that I wanted to do on the characters. I’ll post my results when I get a chance.
Ben
Ben Hale
December 22, 2009 at 4:15 amRan into a problem. Your idea was working great past the inverted Alpha section, but once I got to the blur all the problems started. Rather than just pull the colors from within the Alpha channel, it also started pulling from the outside and forming these “halo’s” around the shapes. I’ve attached an image.
The matte choker wasn’t working as well as I’d like so I tried creating an adjustment layer and using the duplicate layer’s Alpha channel to try and contain the blur to only the area masked by the 2 colors. It was still pulling color from outside the Alpha channel. I was really hoping that the “repeat edge pixels” would fix it, but no luck.
I’m open, and appreciative, of any more ideas. Thanks.
Ben
Walter Soyka
December 22, 2009 at 3:16 pmDoes it help if you precompose the layer after adding the color keys and invert alpha, but before the blur and matte choker?
Also, this might be easier to do on the shading itself, instead of the composited final. Do you have the animation in layers somehow?
Walter Soyka
Ben Hale
December 22, 2009 at 3:43 pmI think I tried precomposing last night, but I’ll give it another shot later. As far as the actual animation, its not layered in a way that the color groups would be separate.
The original idea seems sound, I just can’t get the blur effect to respect any masks that I put on it. Not sure if there are any other “blur type” effects that might give me a similar blending effect without the problems.
Is there a way to get After Effects to trace the shape of the mask I’m creating after the invert Alpha step? I haven’t tested it yet, but the blur filter might not pull outside the mask if it was something drawn with the pen tool. Thought I heard of an auto-trace somewhere, but I could be wrong.
Thanks again for your help.
