Activity › Forums › Apple Final Cut Pro Legacy › DISK WARRIOR to defrag main internal hard drive- FCP
David Roth weiss replied 17 years, 1 month ago 8 Members · 19 Replies
David Roth weiss
June 1, 2008 at 9:04 pm[Randolph Harrison] “Thanks again, David”
You welcome Randy… Just send my residuals to DRWFTAF, the David Roth Weiss Foundation for the Terminally Addicted to Filmmaking.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Jeremy Garchow
June 2, 2008 at 3:38 am[Peter von Puttkamer] ” Kona’s not really letting me do it, right now”
That’s because you are changing frame rates. The Kona does a lot of things, but it won’t conform your 720p60 to 1080p24. You can cross convert and capture @ 1080p30 and then conform that to 24p if that will suit your needs. The Kona’s cross convert works very well, it’s just that the time base of the video has to remain the same.
Jeremy
Kevin Monahan
June 2, 2008 at 5:54 pmYes, it’s a good idea to reinitialize the drives between major projects.
Kevin Monahan
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro -
Bob Tanner
July 31, 2009 at 12:16 pmHi Rafael,
I’v been experiencing a slow mac and I wanted to know how to rebuild the my internal HD which is my start up disk. Is there any way to rebuild it, because I get a message that it cannot be rebuilt because it is the start up drive.
Zevie -
David Roth weiss
July 31, 2009 at 2:59 pmIt’s clear you haven’t read the Disk Warrior instructions Zevie, which are printed right on the original disc, which you will need in order to defrag the system drive. If you have a borrowed copy installed on your computer, it will not work.
David Roth Weiss
Director/Editor
Zane Barker
July 31, 2009 at 4:20 pmZevie first off this thread is over a year old, it would be best if you had started a new thread to ask your question.
There are clearly some things that you do not under stand about disk warrior.
1- Disk warrior does not do defrag anything. It is used to repair corruption on hard drives.
2- You cannot defrag or repair a disk that you are booted from. You must be booted from another hard drive or from a CD/DVD.Before you do anything the most common reason that a hard drive would make a computer slow is if it is to full. Make sure that your drive has 10-20% free space on it.
There are no “technical solutions” to your “artistic problems”.
Don’t let technology get in the way of your creativity! -
Bob Tanner
August 2, 2009 at 8:39 amThanks, I don’t own DW yet, I think I’m going to go with a clean restore, I’m looking into buying internal hard drives for Mac Pro and I was wondering if the Mac Pro can handle a single 2 TB drive? And which company would you recommend, Western Digital or Seagate?
David Roth weiss
August 2, 2009 at 4:39 pm[Zevie Tannenbaum] “I was wondering if the Mac Pro can handle a single 2 TB drive? And which company would you recommend, Western Digital or Seagate?”
Yes, 2Gb drives will work. I recommend Hitachi over all other brands because every Hitachi SATA drive I’ve bought over the last four years is still operating perfectly. However, if you have a preference for Seagate or Western Digital, they’re good too.
David Roth Weiss
Director/Editor
