Activity Forums Apple Final Cut Pro Legacy Disk Warrior and Xserve RAID?
  • Disk Warrior and Xserve RAID?
    Posted by Matt Larson on September 15, 2005 at 8:34 pm
    Is it ok to use Disk Warrior on a RAID 50? Any special considerations because it’s a RAID, or is it basically one big ol’ disk to Disk Warrior?
    John Lanza replied 21 years ago 3 Members · 2 Replies
  • Tony! Hulette
    September 15, 2005 at 9:15 pm
    It will work fine. Use the latest version of Disk Warrior only. Most likely it won’t find anything that needs repair if you’re using your RAID for video. Having said that, I would not run it in the middle of a job/s and I would be very hesitant to run it without a backup of the RAID somewhere. I’ve never had a problem on my Xserve RAID’s with Disk Warrior, but I did loose everything twice when using Disk Warrior on my Huge Systems RAIDs (I think it was an issue with Huge and/or ATTO, but Huge tried and tried and was never able to figure out what caused the data loss).
    Tony!
  • John Lanza
    September 19, 2005 at 2:17 am
    I just used Disk Warrior, and we have the Huge Systems Raid.
    So far, I can’t complain.
    John
