Activity › Forums › Apple OS X › disk utility? no help? what?
  • disk utility? no help? what?
    Posted by Nate Abramow on February 19, 2006 at 9:49 pm
    i’ve always read that after you install new software or upgrade you should always use disk utility to repair you disk permissions…
    for the first time it failed me and now really freaks me out…
    i upgraded compressor and went to repair my disk permissions and about a third of the way though it came up with a “unable to connect to disk management” error and “must quit” and then i went to quit – it opened up another window that says something along the lines of …”if you quit now in the middle of repairing your permissions it may leave the disk unoperational”
    help?? what’s happing with disk utility? this is the first time this has happened!!
    i actually tried to read up on it and couldn’t find anything…so then i quit the program, restarted with disk warrior to rebuild the os hd…when i did that i came up with a “wrapper drive” error and must fix that…so i did…then rebuild the drive…then tried to repair my disk permissions agian…same error….
    it’s really starting to worry me….anyone who can shead some light on this it would be much appreciated….i simply don’t know what to do and i do not want to run disk utility again and get the error…
    i’m running 10.3.9 on a powerbook g4 1.2 80gig hd
    thanks in advance
    nate
    Superfresa66 replied 20 years, 7 months ago 4 Members · 5 Replies
  • Don Greening
    February 20, 2006 at 12:57 am
    Are you running iTunes 6.0.2? I f so, drag the program to the trash but DON’T empty the trash. Restart and run Disk Utility. Repair permissions and then drag iTunes back out of the trash and use as usual.
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?univpostid=855937&forumid=71&postid=855937&pview=t
    – Don
  • Nate Abramow
    February 20, 2006 at 3:01 am
    wow…i would have never guessed that…that’s a crazy fix…
    it worked and i cannot thank you enough. i was freaked out about it.
    but it worked…i’ll pass along the info…
    thanks again,
    nate
  • Jeff Carpenter
    February 20, 2006 at 4:43 am
    We can finally stop doing this funny work-around.
    iTunes 6.0.3 is out now. I tried out disc utility after updating and it worked fine. They finally fixed it!
  • Don Greening
    February 20, 2006 at 5:43 am
    Exellent! Thanks Jeff.
    – Don
  • Superfresa66
    February 21, 2006 at 4:20 am
    I just got the same problem… same error on the disk repair… i put my iTunes in the garbage, restarted, did disk per… and put iTunes back, and it worked, BUT (There is a But) I had iTunes 6.0.3 Same problem as the one he had with 6.0.2…. I hope Apple gets this fix… Anyone esle with the same problem runing iTunes 6.0.3
    Cesar Martinez
    Videographer & Editor
    “You’re as strong as your weakest element”
