Activity Forums Apple OS X Disk Utility Error “Please Help”
  • Disk Utility Error “Please Help”
    Posted by Sean on June 8, 2005 at 7:33 pm
    I’m running Panther on a G5. I’m having problems trying to raid
    two Seagate 160 Gg SATA hard drives together with Disk Utility.
    Both drives showup in DU and then I choose the RAID tab and drag
    both drives to the RAID window select STRIPE and then name the
    Volume followed by choosing “OS Extended” then select CREATE.
    It starts to do the creation of the RAID and then give me this error:
    “RAID set failed due to the following error: Could not bring raid
    set online”
    and it wont mount the new RAID set, Even thou it show the raid set
    in the Disk Utility list.
    I’m very confused… ANy help or Ideas would be great!
    Sean
    Jeff Carpenter replied 21 years, 3 months ago 2 Members · 1 Reply
  • Jeff Carpenter
    June 8, 2005 at 7:44 pm
    I would start by erasing each drive and formatting it as an individual drive. Perhaps there’s something on it that’s messing it up? I don’t know, but it’s something to try. I forget, does Panther have the ability to write zeros to the entire disk? If so, select that option.
