Activity Forums Blackmagic Design Disk speed for 8 bit capture
  • Disk speed for 8 bit capture
    Posted by Sameer Shrivastava on May 7, 2005 at 11:59 pm
    I have a raid with more than 100 mbs read/write i/o as reported by decklink speed utility. recently i wanted to capture a lot of material so i tested my single ide drives(7200rpm) they reported 43mbs write speed when connected on the system board and if connected through firewire port 30mbs. I tested capturing 8 bit footage on these drives and they were ok. they did not report dropped frames.
    Should i use them for 8 bit capture if need arise? I am using premiere pro.
    thank you
    sameer
    Sameer Shrivastava replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
