Activity › Forums › Avid Media Composer › Disk Drive Problem
Disk Drive Problem
Posted by Brian Thomas on June 27, 2008 at 4:48 pmI have determined that video overruns and choppy playback issues are related to my internal separate 465gb hitachi deskstar hard drive…there are no problems in the windows disk check…please advise as to what my next steps are to solve this problem
Thanks in advance
Brian
specs
HPWorkstation 8200
Avid Media Composer v2.81 with Avid MojoAvid Editor
New York CityScott Cumbo replied 18 years, 2 months ago 5 Members · 9 Replies -
Michael Hancock
June 27, 2008 at 5:46 pmHmmm. Your post is a little vague, so we’ll probably need more info to really help.
This info would help:
How fast is the hard drive (5400, 7200, 10K)? Is it SATA? IDE? How full is the drive? Is all your media on this drive, with none on your system drive? What resolution is the media you’re trying to play back? Is the audio sample rate the same as your project sample rate? How many layers are you trying to play? Any effects? If there are effects, are they rendered?
I’m guessing the drive is too full, it’s not fast enough, or it’s a combination of the resolution you’re trying to play back and the speed of the drive.
Michael.
Brian Thomas
June 28, 2008 at 1:44 amno way…i reformatted the drive, nothing on it, no layers no effects…but i can play video fine from a 40gb firewire drive…i’m not sure how to test/replace/reseat/fix/ the internal hard drive
thanks
Avid Editor
New York City -
Jon Zanone
June 28, 2008 at 4:06 amAccording to a quick search (clicky thing), your drives are running at 7200rpm – not fast enough to play back video.
Jon
“So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
Del Amitri – “Make it Better” -
Chuck Reti
June 30, 2008 at 1:57 pm[Jon Zanone] “your drives are running at 7200rpm – not fast enough to play back video.”
This comes as a great surprise to the thousands of us using 7200rpm drives, internal and external, IDE, FW and SATA, for SD video.
Jon Zanone
July 1, 2008 at 12:40 amI stand corrected. Just regurgitating old wives tales…
Jon
Brian Thomas
July 1, 2008 at 1:14 amAvid has told me that i should partition the drive as avid does not recommend drives over 250gb …. i do not want to pay money for partition software because this drive worked for over a year before i encountered video playback errors on it…but if this is the case..can anyone advise me how to partition, or any other advice?
thanks
Avid Editor
New York City -
Scott Cumbo
July 1, 2008 at 4:19 amAvid recomends the 250gb limit if your using OMF media.
If you use MXF media you don’t have to worry about that limit.On my system at home I use 500gb ide drive with no problem and thats on a unqualified VERY outdated PC. But that’s dv25 resolution (I’ll uprez my side projects at work to 2:1 or 1:1 depending on the project)
What resolution are you working at? also those hitachi deskstar drives are pretty famous for failing. your drive may be starting to go.
Scott Cumbo
Editor
Broadway Video, NYC -
Brian Thomas
July 1, 2008 at 3:50 pmthanks Scott
let’s just assume that the drive failed…can it be taken out and repaired?…should i replace it with the same drive?…should i buy and external…any advice would be greatly appreciated?
Avid Editor
New York City -
Scott Cumbo
July 1, 2008 at 4:04 pmHow old is the drive? If it’s not too old you could try sending it back. But you can buy an internal IDE drive for under $100 these days.
If you don’t need it to be portable, the only real advantage of external drives are you only start’em up when you need them. So that saves some wear and tear on the drives. IDE drive will start everytime you start your pc. Most of the damage/wear is done to a drive when the spin up or down.
I usually get drives from zipzoomfly.com they have decent prices and I’ve never had a problem with them.
good luck
Scott Cumbo
Editor
Broadway Video, NYC
