Activity Forums Adobe After Effects Disk Cache WTF
  • Disk Cache WTF
    Posted by Dominik Bochenski on February 13, 2008 at 5:00 pm
    I’m scratching my head over this.
    I’m working with the latest version of AE, brand new Mac, working off SAN capable of real-time uncompressed playback.
    I want to use disk caching since I have the drives to support it. When I enable this, sure, blue bars appear in my sequence but they seem to be ignored. When I do a Ram preview, it still generates the green RAM bar, but when it runs out of memory it just plays back what it cached to RAM… Disk caching does nothing.
    Any suggestions. I’m stumped.
    Dominik
    Darby Edelen replied 18 years, 6 months ago 2 Members · 2 Replies
  • Dominik Bochenski
    February 13, 2008 at 6:07 pm
    So does anyone know of any tricks to max out the RAM preview? I’m working in 2k so even with loads of ram I can only playback 5 seconds worth.
  • Darby Edelen
    February 13, 2008 at 7:21 pm
    [Dave LaRonde] “As I understand it, AE uses disk chaching to render items that are unlikely to change in a comp”
    My understanding of Disk Caching is that it only occurs when the RAM Cache is full and AE thinks it will be faster to retrieve the frame from disk than it would be to render it. However, that said I’m pretty sure that during a RAM preview AE will only work with frames that are loaded into RAM, so you are benefitting from the Disk Cache in that AE does not need to re-render the frames cached on disk, but it still needs to copy those frames from Disk into RAM for a RAM Preview.
    From Adobe’s help documentation:
    “The disk cache is not used for RAM previews.”
    https://livedocs.adobe.com/en_US/AfterEffects/8.0/WS155A1BB2-BB32-4833-A079-F8396553D7B0.html
    and…
    Enable Disk Cache Moves rendered frames to your hard disk when the RAM cache is full. After Effects will only use the disk cache to store a frame if it’s faster to retrieve a frame from the cache than to re-render the frame. Select a folder to contain your cache, and click OK (Windows) or Choose (Mac OS). For the best performance, select a folder that’s on a different physical hard disk than your source footage. If possible, the folder should be on a hard disk that uses a different drive controller than the disk that contains your source footage. The disk cache folder can’t be the hard disk’s root folder.”
    https://livedocs.adobe.com/en_US/AfterEffects/8.0/WS0CDB46BA-BA44-4d0b-91EC-6CB52E1395FB.html
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
