Activity Forums Boris FX Particle Illusion Disintegrating people tutorial – stuck, some help please!
  • Disintegrating people tutorial – stuck, some help please!
    Posted by Mandyyjobs on September 9, 2005 at 9:36 pm
    In the tutorial, Elivis says :
    “We’ll also change the End box under Sequence/ AVI so that rather than playing for 65 frames, the clip only plays until frame 58. Once we hit Ok and go back to the scene, hitting play will show us the changes.”
    Where is the END BOX under AVI in the background options panel? I only saw HOLD FRAME, UPPER/LOWER/OFF SEPARATE FIELDS.
    I really can’t get past this point, because I am unsure of what he meant. Also, when trying to open the project file – it says ‘Not a valid PI file’, so there is no help there either. any ideas?
    I am using PI3.0 on Windows.
    Mandyyjobs replied 21 years ago 2 Members · 2 Replies
  • Alan Lorence
    September 9, 2005 at 9:55 pm
    You should be using 3.0.1a. Check the wondertouch downloads page.
    Alan.
    wondertouch
  • Mandyyjobs
    September 9, 2005 at 10:12 pm
    Thanks, I will do that.
    Also in the tutorial, is the emitter getting the changes in number or is the particle? Maybe that is where I am going wrong…
