Activity Forums Apple Final Cut Pro Legacy discrete audio in quicktime
  • discrete audio in quicktime
    Posted by Mark Fason on October 11, 2005 at 4:20 am
    i’m trying to make quicktime files for my music composer and i need all my narration, interviews and sound effects panned one way and all my music panned the other, i tried to go into the audio tab on the sequence settings and seperate everything there but after a few different attempts it is still all mixed together. if anyone has any input it would be greatly appreciated.
    thanks,
    mark
    Andy Mees replied 20 years, 11 months ago 2 Members · 1 Reply
  • Andy Mees
    October 11, 2005 at 7:46 am
    hi Mark
    sounds like you already found the audio outputs tab inder the sequence settings … where you set the grouping to dual mono.
    now before you output, you need to assign the track output channels… right click in the lock/autoselect area of each track, the first option in the drop-down menu is audio outputs, select the apropriate output track from the submenu. do this for each track and you should be good to go.
    hope it helps
    Andy
