Activity Forums Apple Final Cut Pro Legacy Discrete Audio Channels for H.264 Compression
  • Discrete Audio Channels for H.264 Compression
    Posted by Aaron Barton on July 5, 2012 at 4:20 pm
    Hey guys,
    So I’m trying to make a Quicktime H.264 with 8 channels of audio from a Quicktime ProRes HQ file that has 8 discrete audio channels. The problem I’m having is that when I bring the HQ file in to Compressor, it shows up as stereo and not having 8 discrete channels of audio. Is there a way to change the way Compressor interprets the file it’s about to compress?
    Aaron
    Tina Hedegaard replied 14 years, 1 month ago 2 Members · 2 Replies
  • Tina Hedegaard
    July 6, 2012 at 8:18 am
    Hi aaron
    If you choose AAC in audio settings, then you will have more options. Hope it helps.
    Cheers
    Tina Hedegaard
    Editor | Assisting Editor
    Final Cut Pro 7 | Media Composer 5.5.3/6.0.1.1
    Mac OS 10.6.8| Mac OS 10.7.4
  • Tina Hedegaard
    July 6, 2012 at 8:20 am
    Or actually you can also choose the PCM (better audio) and you will have even more options
    Cheers
    Tina Hedegaard
