Activity › Forums › Adobe Illustrator › Disconnecting Paths that reconnect to themselves
  • Disconnecting Paths that reconnect to themselves
    Posted by Wade Stubanas on March 16, 2012 at 3:10 pm
    I am attempting to modify a path. During the removal of points, I came upon a spot where the path connects to itself and forms a kind of island. If I continue deleting points, I will lose parts of the path I want to keep. How can I remove this section?
    Please note that the part I want to remove does not have a blue outline and I cannot add points to it…
    Vincent Rosati replied 14 years, 6 months ago 2 Members · 1 Reply
  • Vincent Rosati
    March 17, 2012 at 1:25 am
    I suspect that you deleted the paths between the points at the ends of the parallel section, or their otherwise are simply no paths there – indicated by:
    ‘the part I want to remove does not have a blue outline and I cannot add points to it’
    You probably need to use the Pen tool to close the paths.
    When you attempt this you might get the Same Path/Endpoints error. If this happens, you’ll probably have to either Object/Expand the object and/or ungroup the object before you can close the paths.
    Try what I mentioned, and if you still can’t get it to work you can always upload the file and I’m sure someone will fix it for you.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
