Activity Forums Adobe After Effects Disco ball light effect
  • Disco ball light effect
    Posted by Michaelle Stikich on October 14, 2006 at 11:31 pm
    Hi everyone,
    I’m trying to create a disco ball reflection effect. Basically, I never want to see the ball, I just want to see the light reflected off the ball onto my comp. I want to choose the source of the light and then have it rotate.
    Does anyone have any tips and tricks for this?
    s
    Manny Rellesiva replied 19 years, 11 months ago 3 Members · 2 Replies
  • Mike Clasby
    October 15, 2006 at 1:40 am
    Disco Ball: If you mean the little light squares that are projected on the Walls and dancers, this isn’t bad.
    Two layers: A white solid with Grid and Polar Coordinates (overlay mode) to give the pattern of light squares above the video clip of your dance scene).
    Layer 1) White Solid, 2 to 3 times the size of the comp.
    Render>Grid
    Size From: Width & Height Sliders
    Width and Height: 30,40, to your specs, will adjust later to resize projected squares
    Border: 20 (tweak)
    Invert Grid: Check the box
    Distort>Polar Coordinates
    Type of Conversion: Rect to Polar
    Move the position of the White layer so it’s at the lower right corner of the layer to be projected on (below), or somewhere else off-screen, whatever looks good.
    Change the Mode to overlay.
    Rotate the white solid with keyframes, 1 rotation over about 10-12 sec (to taste)
    Optional tweaks:
    You can also add a little Blur>Vector Blur, Natural at about 4 to give it a little star shape.
    Or
    Distort>Turbulent Displace to give the light path a little variation.
    Layer 2) Dance Scene or the layer you’re projecting onto.
    Of course this doesn’t displace the light over the dancers correctly, you’d need a displacement map (may be complicated) but the above can give an impression of the light squares projected onto a scene. As an alternative you might checkout Rick Gerard’s tut on Gobos and light projection here:
    https://forums.creativecow.net/cgi-bin/page_wrapper.cgi?forumid=2&page=https://www.creativecow.net/articles/gerard_rick/Projection_tut/index.html
    By the by, Serge has a nice Disco Ball here:
    https://www.nyc-visual.com/Disco_Ball_M.html
  • Manny Rellesiva
    October 16, 2006 at 1:40 pm
    If you are using After Effects 7.0 …try the preset animation palete. Go to Animation Presets > Synthetics > Globe rays. It looks like a disco ball and you can see the different effects used.
