Activity Forums Adobe Photoshop Discarding data outside the canvas
  • Discarding data outside the canvas
    Posted by Brent Warwick on May 31, 2005 at 2:45 am
    Is there an easy way to discard data on a layer that is outside the size of the canvas? If I have a graphic layer I imported from a digital photograph, I can scale and position it as necessary, then I want to get rid of all the image data that lies outside the edge of the canvas.
    Ideas?
    -Brent
    Filip Vandueren replied 21 years, 3 months ago 2 Members · 1 Reply
  • Filip Vandueren
    May 31, 2005 at 2:57 am
    You can simply “select all”, then crop.
    It will cut off all exces graphics on all layers.
    If you want to do it on only 1 layer, I think the easiest way would be select-all, then Float the layer with control-J (or Command-J on mac)
    It will create another cropped layer above the one you’ve selected, so you’ll have to throw away the first one.
