Activity Forums Adobe Encore DVD disc image question
  • disc image question
    Posted by Carl Endres on December 18, 2008 at 1:06 pm
    I finished a project recently in which I created a disc image and then created dvd copies from that.
    Prior to doing that I made a test disc using the option make DVD disc (only 1 copy)
    When I put the test disc in, the main menu loads normally.
    When I put the disc that was created using the disc image, it takes almost 60 seconds to bring up the main menu. It plays fine…just an exceptionally long wait for the main menu to come up.
    Both discs were created from the exact same project and the project was checked using the “check project” feature and no errors were reported.
    Any ideas why this is occuring – Thanks for any help – Carl
    Carl Endres replied 17 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
