Activity Forums Adobe After Effects Expressions Disappearing ScriptUI elements in docked panel problem
  • Disappearing ScriptUI elements in docked panel problem
    Posted by Joshua Faget on September 14, 2016 at 6:29 pm
    Hello,
    Im facing the following issue. I wrote a script where you input a #HEX color and it pops a little square with that color… you can add a whole bunch of them.
    The problem is that when I open the “Color Picker” or “Make a New Comp” window is open… all of the colored squares disappear until that window is closed.
    Here is a before and after opening the “New Comp” menu…
    Are there any solutions so that the colored box doesn’t disappear?
    //how the button is created
    brn.onClick
    var box1 = PalGroup.add("group", [0,0,30,30] , 'Box' + suffix.toString()); //Adding a box
    var graphic = PalGroup.graphics; //PalGroup is the group where all the boxes pop in...
    var Brush1 = graphic.newBrush(graphic.BrushType.SOLID_COLOR, hexToRgb); //creating the brush
    box1.graphics.backgroundColor = Brush1; //assigning the brush to the Box
    Jay Brown replied 8 years, 10 months ago 2 Members · 1 Reply
  • Jay Brown
    October 25, 2017 at 3:12 am
    Did you have any luck figuring this out?? Running into the same problem
