Activity › Forums › Apple Final Cut Pro Legacy › Disappearing Patch Panel Sources
Posted by Rob Chinn on October 4, 2008 at 9:40 pmI was wondering if anyone has run across a similar problem recently in FCP 6.0.4. I was at a client doing some training this week and we ran into this problem on several MacBook Pros with OS 10.5.4.
For some unknown and random reason, the source side controls of the patch panel (sometimes it was just the video ones, mostly just the audio ones, but sometimes it was all of them). I couldn’t pin down a reason or anything in particular that anyone was doing to cause it. I haven’t seen it happen on either one of my machines. The only solution for it I could find was to quit FCP and restart it, and that seemed to bring them back, at least for a little while. Resetting the patch panel had no effect.
Any ideas?
Chris Conti replied 15 years, 2 months ago 13 Members · 16 Replies -
Jerry Hofmann
October 5, 2008 at 7:10 amGot a screen shot?
Note that only the tracks included in the Sequence will show up on the right, and only the tracks that a Viewer clip has will show up on the left. so it’s possible to put a video only clip in the Viewer, and no audio patches will be on the left, etc..
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
Rob Chinn
October 5, 2008 at 11:37 amJerry,
Thanks for the response. No, I didn’t get a screen shot. I’ll be back there again this coming Thursday, so I’ll get one then.
I understand what you’re saying. The only ones that were missing were the source side. I didn’t see every case where people said they didn’t have them, but at least 2 of the cases I saw had a video clip loaded in the viewer that definitely had audio, but there were no source side patch plugs, video or audio.
I’ll keep a closer eye on it this week, and I’ll be sure to grab a screen shot and let you know what I find.
Rob
William Watts
October 6, 2008 at 8:58 amRob,
This can happen if you patch source tracks to timeline tracks and then delete the relevant timeline tracks (if autopatching is not activated).
Try adding tracks to your timeline or turning on autopatching ?Regards,
Will.(editor,Soho Asia Co. Ltd.,Bangkok)
Tom Matthies
October 6, 2008 at 1:14 pmControl Click in the gray area between the green “speaker” icon and the audio track indicators in the audio portion on the left of the timeline. You will get the option to “reset panel”. This should fix your missing patch source problem.
Tom -
Rob Chinn
October 6, 2008 at 1:18 pmTom,
Thanks for your reply. As stated in my original post, I tried resetting the patch panel, but it had no effect the multiple times I tried.
Rob
Rob Chinn
October 6, 2008 at 1:21 pmWill,
Thanks for your reply. I don’t think any tracks were deleted, as the people I was working with were newbies, but I suppose that it is a possibility. No one stated they had deleted a track, but I suppose that doesn’t mean they didn’t. It happened multiple times on multiple machines though, but….
I will check into it when I am there again on Thursday.
Rob
Tom Wolsky
October 6, 2008 at 1:22 pmThe source patches are always controlled by the content of the viewer as Jeff said. I have never seen this not work. But if there is a glitch make sure you trash your preferences, repair permissions and reboot.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Andy Mees
October 6, 2008 at 2:24 pmyou can force source patches to disappear by using the keyboard shortcuts and targeting a track number that doesn’t exist eg if you have just two video tracks then press F6 followed by 3 … and you can get it back by re-targeting an extant track eg F6, 1. Same goes for audio tracks (using F7 and F8). See if pressing F7, 1 and F8, 2 will recover these errant patches
Carlos Borges
September 28, 2009 at 7:52 pmI read this online, it may help you understand how the patch panel works and how it relates to the missing source buttons on Video and audio.
When a clip (the source) is opened into the Viewer, the Source controls in the Timeline update. These controls are basically a reflection of what’s in the Viewer. For instance, if you open a clip with only two audio tracks into the Viewer, you will see two audio Source controls in the left side of the Patch Panel, labeled a1 and a2. If you then open a video only clip into the Viewer, the Patch Panel will change. The two audio Source controls disappear and are replaced by a video Source control, labeled v1.
On the right side of the Patch Panel are the Destination controls. These controls represent the possible Timeline tracks where the clip in the Viewer can be placed. Before editing the clip into the sequence, Source controls can be moved up or down to different Destination controls, changing the track where the clip will be placed.
So the source side of the patch panel only reflects what you have opened in the viewer and how it will react to being added to the timeline once added. the patch panel decides where the relevant tracks are placed into the timeline.
Hope this clears it up for anyone else who may read this thread …. it helped me, I was just having the same issue. I spent about 10 minutes trying to find out why these things were disappearing. Now I know.
Make some cash in your off time.
http://www.profitlance1.com
