Activity Forums Boris FX Disappearing display
  • Disappearing display
    Posted by Mark Rothman on April 21, 2008 at 6:02 pm
    I’m a new user, in love with Red until …
    In the standalone engine only, if I apply a border, a mask, or a crop, the moment I release a slider or hit return after entering a value, the display for all layers disappears, leaving me looking at a checkerboard with some interactors and a bounding box showing where the image should be.
    The display only reappears when I return values to “0”
    Ideas? Everything works fine from within Premiere.
    Mark Rothman replied 18 years, 5 months ago 2 Members · 2 Replies
  • Peter Mcauley
    April 23, 2008 at 12:46 am
    Hi Mark,
    It might be that you are have OpenGL enabled and other resources on the system are vying for control of the board. What happens if you disable OpenGL preview in RED … do you see the same result as you reported? What are the specs of the system on which you are running RED and experiencing these symptoms?
    Peter.
  • Mark Rothman
    April 23, 2008 at 9:56 pm
    Hi Peter,
    Yes, the standalone engine works fine if I turn off OpenGL. The Premiere plug-in works fine with OpenGL turned on — I double checked.
    I have a Dell Dimension 390 with 4GB of RAM and a 2.93mh core-duo processor, running XP Pro SP2. Here’s the info from the OpenGL test. Thanks.
    Graphics Card: Quadro FX 3500/PCI/SSE2
    OpenGL Version: 2.0.3
    Driver Version: 6.14.10.9136
    Texture Rectangle: false
    Texture Memory: 256 MB
    Texture Dimension: 4096 x 4096
    Hardware Status: Supported
    Critical Testing: Successful.
