Activity Forums VEGAS Pro Disappearing audio/waveforms (?) – Vegas Pro 13
  • Disappearing audio/waveforms (?) – Vegas Pro 13
    Posted by Christian Mikkelsen on November 27, 2016 at 2:49 am
    Hello!
    So for the past few months I’ve been having an extremely frustrating issue bothering me.
    The problem is basically disappearing audio, as weird as that sounds. Sometimes an audio clip will take sound from another clip, other times there’s no audio at all.
    I can visually see this, when I scroll to zoom in on my audio wave forms, like seen in these gifs:
    https://i.gyazo.com/199b0ee3ce4ec577338b14e52a73185c.mp4
    (Zoomed out you see the original waveforms, but zoomed in it takes audio from another track and plays this in its place.)
    https://i.gyazo.com/b929c5464d52ae3cc89615400149f9d2.mp4
    (Here the audio compeltely shifts and repositions itself)
    During playback, the audio does not play what its originally intended to, and the only real fix I’ve found is just restarting Vegas until I somehow can work in peace for 5 minutes before the same begins again.
    These are completely normal .mp3 and .wav files that I work with.
    Here are my PC specs, should it carry any significance;
    Windows 10 Pro
    Intel i7 4770k 3.5GHz
    16GB ram
    GeForce GTX 970
    Any other relevant information I’d be glad to provide!
    I would love to know if anyone else has experienced something similar to this and if there’s any solution to this nightmare.
    Thank you.
    Rebecca Chivers replied 6 years, 5 months ago 4 Members · 13 Replies
  • 13 Replies
  • Ole Kristiansen
    November 27, 2016 at 10:05 am
    Do you have the mediainfo of your footage ?
    Where do you live ?
  • Christian Mikkelsen
    November 27, 2016 at 2:21 pm
    I haven’t added any video files yet, but this is what I currently have imported to my timeline;
    – a stereo .mp3 music track; 44,100Hz, 320Kbps
    – an stereo .wav commentary track; 44,100Hz, 16 bit
    – an ambient .wav track; 44,100Hz, 16 bit
  • Ole Kristiansen
    November 27, 2016 at 3:07 pm
    Can you import, to the timeline, one by one and play with out problems ?
    November 27, 2016 at 3:26 pm
    I tried making a new project file, then added the music (.mp3), which worked just fine by itself. Then I added the commentary track (.wav), seemed alright. Finally adding the ambient sound (also .wav) and playing them all together worked just fine the first time around.
    Merely seconds after playback this is what it looks like; https://i.gyazo.com/7b1c53dc890329e0e2a83c784afd154c.mp4
    Adding them one by one, seems to work for a limited time before they somehow “merge” (?) I’m honestly baffled and having a hard time explaining myself.
    The problem just appears out of nowhere it seems. Could it be that Vegas isn’t fond of working with both mp3 and wav formats at the same time?
  • Ole Kristiansen
    November 27, 2016 at 3:42 pm
    If you go to: Options – Preferences – Audio Device
    Is it set to: Windows Classic Wave Driver ?
    November 27, 2016 at 3:47 pm
    It’s set to ‘Microsoft Sound Mapper’.
    These are all my Audio Device settings; https://gyazo.com/dd6cc0f0d35d5aad459bc46715a31e1a
  • Ole Kristiansen
    November 27, 2016 at 3:53 pm
    What if you change to Windows Classic ?
    November 27, 2016 at 4:01 pm
    Unfortunately it didn’t seem to change or fix anything..
  • Rosh Kadri
    November 27, 2016 at 5:02 pm
    I would report this to Magix, I’m having a similar problem with a disappearing explorer window too. I’m on build 201 fyi, is that what you have?
    November 27, 2016 at 7:30 pm
    Will definitely try to make them aware of it! I’m currently on build 310. Apart from this issue I rarely encounter anything else.
