Activity Forums Adobe After Effects Disapparate Effects-Harry Potter
  • Disapparate Effects-Harry Potter
    Posted by David Reese on July 24, 2011 at 4:30 am
    I would like to recreate the exact same look as seen in this clip from youtube.
    https://www.youtube.com/watch?v=v8nG9mS_qMI
    I understand it won’t look EXACTLY the same.
    Would After Effects alone do this?
    What all must be done camera wise?
    Foot Work?
    PS The effect is around 1:02
    David Reese replied 15 years, 1 month ago 3 Members · 3 Replies
  • Tudor “ted” jelescu
    July 24, 2011 at 11:38 am
    If you want a steady shot like your example then it’s fairly easy. You can either shoot the actors on chroma and then comp them in or shoot a clean plate (my choice- the set without actors). Either way you can isolate the actors with chroma keying or a difference key and then use Mesh Warp to distort them to disappear in a point. The trick will be to use the bezier handles on the mesh to create a smooth organic move. Things like blur (radial set on spin) and glow and maybe Trapcode Shine may add something to the effect.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Christiaan Van eijk
    August 2, 2011 at 5:28 pm
    Hello David Reese,
    As ‘Tudor’ already said: ”With a steady shot like this it is very easy to create this effect”.
    basic steps
    1. Get a camcorder on a tripod
    2. Make sure that you get a clean plate of your background
    3. then just add smoke, a certain blur effect(s) and some distortion
    4. to make the effect look a bit more realistic, create some
    visual camera movement
    i am bysy making a video-tutorial about this effect. as soon i`m finished i will send you a message for that
  • David Reese
    August 13, 2011 at 4:34 pm
    How is the tutorial coming along?
