Activity Forums Boris FX Particle Illusion Disabling automatic keyframe creation…
  • Disabling automatic keyframe creation…
    Posted by Peter Kovacs on January 20, 2013 at 1:46 am
    Is there a way to adjust a value without it creating a keyframe? Often I’m just experimenting with values, playing it back to see how it looks, etc. So I would then end up with a tonne of keyframs at different times, it’s a mess.
    It would be cool if I could adjust a value no matter where I’m at on the timeline, and only create a keyframe if I tell it to. This is exactly how After Effects works.
    Alan Lorence replied 13 years, 8 months ago 2 Members · 1 Reply
  • Alan Lorence
    January 21, 2013 at 3:32 pm
    pI doesn’t work like AE as you’ve found.
    If you want to experiment with changing the value without creating a keyframe, grab the last keyframe (most likely the one at frame 1) and drag it around.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
    http://www.genarts.com
    http://www.wondertouch.com
