Activity Forums Maxon Cinema 4D Disabling a tag
  • Disabling a tag
    Posted by Ben Rollason on October 24, 2010 at 12:39 pm
    Hi All,
    This is a pretty basic question… Is there a way to disable a tag without removing it from an object?
    I need to disable all my visibility tags for a multi-pass render. At the moment, I’m just moving them onto a dummy layer temporarily, but it would be nice if there was a disable feature, that I’ve failed to notice.
    Thanks if you can help.
    Ben.
    vfx.benrollason.com
    Arnold Cortez replied 10 years, 6 months ago 7 Members · 9 Replies
  • 9 Replies
  • Randy Johnson
    October 25, 2010 at 8:32 am
    click the tag
    In the attributes manager (bottom right) in the basic tab there is a check box that says “enabled” uncheck it.
    You can actually animate this too.
    /Randy
  • Ben Rollason
    October 25, 2010 at 3:35 pm
    Thanks, Randy.
    Strange that texture tags don’t have them though. Although I guess you can override a tag with something else.
    -B.
    vfx.benrollason.com
  • Alan Lacey
    October 25, 2010 at 4:34 pm
    This is useful. Can one select multiple tags for dis/enabling.
    Alan
    FlashXDR,XDcamHD,XDcamEX,D9 etc
    FCS,AE,Combustion,LiquidSilver,Vegas,Edius,
    G5,MBP,Vista64,XP
  • Randy Johnson
    October 25, 2010 at 6:49 pm
    Sorry I missed you were talking about textures…
    I have not seen a good way for doing this yet. There are a couple plug Ins that turn textures on and off.
    I just save my project to a new name and delete the textures.
    Yea you can select all the tags you want and on / off Its easyer to set up a boole option in a user data for that type of thing I find.
    /Randy
  • Alan Lacey
    October 25, 2010 at 7:50 pm
    Thanks Randy. I tried that and it works a treat with the display tags
    Alan
    G5,MBP,Vista64,XP
  • Jeremy Solterbeck
    January 12, 2011 at 7:41 pm
    Was just having this problem, and thought I’d chime in. Quite awhile back, the GHOST TAG used to be a part of the JENNA plugin pack, the forerunner of mograph. I used it constantly. I sure wish someone would build a simple on/off switch for tex tags, sometimes they I’ve painstakingly applied several to different objects, and putting the on dummies or otherwise moving them is just not practical. One thing you can do though, is type some garbage into the selection field. This is a quick and simple way, at least for when a selection is not already applied to that tag. And for godsakes, don’t forget you used this method or you’ll be pulling your hair out trying to figure out where the tex is when you want it back!
  • Brian Jones
    January 12, 2011 at 10:53 pm
    https://www.xsyann.com/ has xsTextureSwitch which disables/enables all textures in a scene
  • Alexey Voytikh
    February 25, 2016 at 2:30 pm
  • Arnold Cortez
    March 2, 2016 at 8:12 pm
    Thanks a lot!
