Activity Forums Adobe Premiere Pro Disabled “Filter Bin Contents” Window in Projects Pane ?!?
  • Disabled “Filter Bin Contents” Window in Projects Pane ?!?
    Posted by Max Frank on May 10, 2012 at 2:56 pm
    Quick question here:
    My “Filter Bin Contents”/Search window in the Project pane is disabled in CS6.
    It was working fine when I first installed CS6 a few days ago, but I’m not sure what button I pushed to disable it.
    Any sage advice on how to enable it again?
    Wayne
    David Goodwin replied 13 years, 3 months ago 3 Members · 5 Replies
  • Ron Pestes
    May 10, 2012 at 3:02 pm
    I am having the same problem but if you search for a filter it opens up certain bins. Not sure why.
    ronpesteshdvideo.com
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
    Dell M6600
    Adobe CS6 Production Premium
  • Max Frank
    July 3, 2012 at 8:54 am
    Hi Ron,
    Did you get figure out a way to resolve this issue?
    I did a clean install of Lion and ALL apps – and the Filter Window has disappeared again!
    Hmmmm.
    W
  • Ron Pestes
    July 3, 2012 at 3:56 pm
    I sort of figured it out. It depends on which buttons are selected involving the 32 bit, YUV and the other one which I can’t remember right now. I stumbled on the correct setup but can’t tell you how I did it. Play with those buttons though and maybe it will come back.
    Sony EX-3
    MacBook Pro
    Dell M6600
  • Max Frank
    July 3, 2012 at 8:31 pm
    Thanks, Ron,
    That’s not really working for me – but thanks for the suggestion.
    Wayne
  • David Goodwin
    April 26, 2013 at 7:09 pm
    I’ve got the same problem
