Activity Forums Apple Final Cut Pro Legacy Disable “Save Quicktime File As”
  • Disable “Save Quicktime File As”
    Posted by Kickstand on September 1, 2005 at 9:50 pm
    when i export in FCP Using QUicktime Compression – sorenson3 – then post the video to my site, you are able to right click and save the files.
    has anyone figured out a way to disable or prevent this?????
    KickStand Productions
    Sports Videography/Editing
    Kickstand replied 20 years, 11 months ago 3 Members · 3 Replies
  • John Pale
    September 2, 2005 at 1:18 am
    you need to add Enable Kiosk mode to your HTML code.
  • Paul Dickin
    September 2, 2005 at 9:20 am
    Hi
    An Apple utility called Plug-in Helper used to do this in the days of QT5.
    I don’t know if its still functional in recent versions of QT:
    https://developer.apple.com/quicktime/quicktimeintro/tools/pluginhelper.html
    Also Kiosk mode can be embedded in the actual movie itself using the Export: Movie to QuickTime Media Link mode, and this can also be used to place an unplayable dummy movie in your HTML code, which when clicked on starts the proper movie playing. This means your movie file server location is invisible to a web browser, so your movie can’t be downloaded except to play in Kiosk mode within your web page.
    All the necessary tutorial information about QT Media Link mode is up there on Apple’s QT pages.
  • Kickstand
    September 22, 2005 at 4:53 pm
    I finally had a chance to mess around with this feature. It seems quite easy and i did find the articles on the apple site, however , when the .qtl file is clicked, the video window launches but shows the actual code of the .qtl file. not the video.
    I have gone over the apple site and all my searches lead me back to the one or two pages on the Exporter feature.
    All the code is closed.. and inside the .qtl file i have my URL which is not relative. It is the URL from the hosting site.
    To see this, https://www.reginahammond.com/lanceOLN2.html If you click on “Part 1” you will see
    thanks a lot for any further information. i think i tried all the developer links i could find. it seems quite simple but….
