Activity Forums Apple Final Cut Pro Disable Plug-ins at Start up
  • Disable Plug-ins at Start up
    Posted by Eric Santiago on June 30, 2016 at 3:24 pm
    Is there any way to disable all plug-ins in a project before opening?
    I keep inheriting these projects with multitudes of plug-ins that I don’t own (or plan to own).
    And if there isn’t a way, whats the quickest way of deleting all plug-ins in a project?
    Andreas Kiel replied 10 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    June 30, 2016 at 5:47 pm
  • Eric Santiago
    June 30, 2016 at 5:52 pm
    Thanks Jeremy thats awesome!
    Have you had any experience with it?
  • Jeremy Garchow
    June 30, 2016 at 6:14 pm
    Yes, I use it to clear effects from fcpxmls that are going out to Resolve or elsewhere for conform.
    It’s super easy, works well, and does the job. It shows you a list of effects, you can choose to delete them all, or just the ones you don’t want, and then it autosaves this deletion back to the fcpxml. Import that XML when you’re done and there are no more effects.
    If you like it, be sure to donate! 🙂
  • Eric Santiago
    June 30, 2016 at 7:03 pm
    Last night with client I tried the XML export into Resolve and got me further into the timeline.
    The tip you sent will be the best option since the files were acting up in Resolve.
    I have to get this going in FCPX.
    Thanks again Jeremy.
  • Bret Williams
    July 1, 2016 at 12:43 am
    Does it list all effects, titles, generators and transitions? Even in compound clips? We bought Producer’s Best Friend for this specific purpose and it can’t do it.
  • Jeremy Garchow
    July 1, 2016 at 3:38 pm
    Anything that is based off of a motion template, it should see. I haven’t tested every combination/permutation, but it seems to do a good job of listing everything, even in compounds.
  • Andreas Kiel
    July 1, 2016 at 4:51 pm
    [quote = “Eric Santiago”]
    [/quote]
    That’s what X-FX is made for.
    For any experience with the the app ask the production team of “Focus”.
    They used it on a daily base while producing the movie.
    – Andreas
    Spherico
    https://www.spherico.com/filmtools
    “He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil
