Activity Forums Adobe After Effects Expressions Disable or Enable an Expression with a Checkbox Control
  • Disable or Enable an Expression with a Checkbox Control
    Posted by Nick Mara on September 29, 2020 at 11:38 pm
    Hi Everybody,
    Is there an expression to Enable/Disable an expression with a Checkbox Control?
    So here is my situation:
    I have an expression on the “End” property of a Trim Path and the same expression on the “Start” property of the same Trim Path.
    I would like to know if there’s a way to turn on the expression of the “End” property while disabling the expression on the “Start” property via a Checkbox Control.
    Here is what I mean:
    https://youtu.be/hxEXAh4qf6w
    I hope everything it’s clear enough.
    I would really appreciate your help.
    Thanksss
    Nick Mara replied 5 years, 11 months ago 3 Members · 5 Replies
  • Brendon Murphy
    September 30, 2020 at 2:58 am
    Add a checkbox effect to Shape_Base, then do this on the start parameter:
    if (effect(“Checkbox Control”)(“Checkbox”)==1){
    //put the original start expression here
    }else{value};
    And then this on the end parameter:
    if (effect(“Checkbox Control”)(“Checkbox”)==0){
    //put the original end expression here
    }else{value};
  • Brendon Murphy
    September 30, 2020 at 3:01 am
    make sure to delete the “//put the original expression here”, including the slashes!
  • Stephen Dixon
    September 30, 2020 at 3:18 am
    Simple, use an if() statement
    let chkbx = [link to checkbox control, use the pickwhip];
    if (chkbx.value){
    [your expression here]
    } else {
    value //returns the keyframed value without the expression
    For the other layer use the boolean not operator: “!
     if (! chkbx.value){
  • Nick Mara
    September 30, 2020 at 7:53 am
    Hey Brendon,
    Thank you so much for providing me this expression.
    It works perfectly Star Struck
  • Nick Mara
    September 30, 2020 at 8:03 am
    Hi Stephen,
    Thanks for your answer !!
    I put the first part of the expression on the “End” property of the Trim Path but I can’ t figure out where to put the boolean not operator: “!”
     if (! chkbx.value){
    You wrote “For the other layer ” but the expressions are on the same layer not on two different layers.
    Am I doing something wrong?
