Activity Forums Maxon Cinema 4D Disable Motion Blur for Stage Object camera change
  • Disable Motion Blur for Stage Object camera change
    Posted by Seth Olson on September 10, 2013 at 7:32 pm
    When I use the stage object to jump between other cameras in the same scene, the motion blur carries from the previous camera to the new camera, causing a fade transition between the cameras. I am looking for a hard cut. Is this possible or do I need to switch to a different technique to define shots?
    Thanks for the advice!
    Seth Olson replied 9 years, 10 months ago 3 Members · 4 Replies
  • Seth Olson
    September 11, 2013 at 8:26 pm
    I found out this is actually a known bug and has not been fixed as of R15.
  • Adam Trachtenberg
    September 12, 2013 at 2:38 pm
    Thanks for letting us know.
  • Lars Rietkerk
    November 18, 2016 at 10:34 am
    I’m working in R18 but still get this problem. Any fixes?
  • Seth Olson
    November 18, 2016 at 3:01 pm
    I think I ended up using render layers and assigning each camera and range to a different layer.
