Activity Forums Adobe Premiere Pro Disable Mediacore Plugins
  • Disable Mediacore Plugins
    Posted by Orion Beaufort on April 25, 2012 at 8:04 pm
    I’m using Adobe Production Premium CSS 5.5 on Mac OS 10.7.3 on a 2009 Macbook Pro. I have all the standard Adobe Apps installed, including After Effects, Premiere Pro, Photoshop, Audition, etc.
    I’m using a number of plugins regularly including Particular, Optical Flares, Looks and Colorista, etc.
    They are all installed through the recommended methods and work fine in After Effects. That means they are all in Library/Application Support/Adobe/Common/Plugins/CS5 or CS5.5/Mediacore/
    I’d like to disable all of those plugins in Premiere Pro for two reasons.
    1. I want Premiere to be as lean an editing machine as possible, AE is where all those plugins are used.
    2. Optical Flares sits at the initialize screen and never goes away. This is not the case in After Effects, just Premiere Pro. This means a big initialize screen for Optical Flares hovering over the Premiere Pro interface, even after I’ve loaded a project and timeline.
    The only reasonable option I can think of is to hide the plugins manually when I use Premiere. Anything else?
    Orion Beaufort
    orionbeaufort.com
    United States
    Mae Carzon replied 13 years, 6 months ago 3 Members · 4 Replies
  • Ann Bens
    April 25, 2012 at 10:36 pm
    You cannot disable, you need to install the plugins in AE’s plugins folder.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Orion Beaufort
    April 26, 2012 at 5:22 pm
    Ann, do I just cut and paste? Thank you!
    Orion Beaufort
    orionbeaufort.com
    United States
  • Orion Beaufort
    April 26, 2012 at 5:27 pm
    It worked great, Thank you very much Ann!
    Orion Beaufort
    orionbeaufort.com
    United States
  • Mae Carzon
    March 22, 2013 at 4:40 am
    I realize it’s been quite a while but I just wanted to get feedback on your set up? ( AE plug ins and Adobe premiere pro in the same machine), no CPU and Ram issues so far? I’m still a bit hesistant to load up 3rd party plug ins into the editing machines, I usually put a separate machine to help with the heavy lifting ( effects and compositing ). Thanks.
