Activity Forums Maxon Cinema 4D Disable Dark Bands in Cinema 4D R24’s Render View?
  • Disable Dark Bands in Cinema 4D R24’s Render View?
    Posted by Mauricio Barrientos on September 22, 2024 at 9:48 pm
    Every time I enter the 3D Cinema R24, the screen seems split, dark at the top and bottom, and it’s the rendering format… My question is if I can configure the cinema so that every time I open it, it starts without that… but WITHOUT THAT FORMAT to use the full screen for work… please… I will appreciate any help as always… I’m leaving a photo showing in brackets the dark part I want to remove.
    Brie Clayton replied 1 year, 11 months ago 4 Members · 6 Replies
  • Kouraib Abdmalek
    September 24, 2024 at 11:48 am
    Hi Mauricio,
    You could do this by setting the width and height in the output 815*720 pixels then following the steps in the tutorial below so you won’t have to repeat this every time, just let me know if this works for you.
    https://www.youtube.com/watch?v=Z5D8i32Ajd8
  • Mauricio Barrientos
    September 24, 2024 at 2:38 pm
    Thank you for the help, … I have a Mac …… OSX Ventura [[C4DR24]] and it worked the same way …. I even added my own lights and everything is ready to start with that template …. thanks again !!!!
    October 12, 2024 at 9:49 pm
  • Kevin Rad
    October 17, 2024 at 1:14 pm
    I had the same problem. Thanks Kouraib for the tip. 🙌
  • Kouraib Abdmalek
    October 18, 2024 at 7:31 am
    You are welcome, Kevin! So glad that was helpful to you.
  • Brie Clayton
    October 18, 2024 at 1:51 pm
    Thanks for solving this Kouraib!
