Activity Forums Boris FX Particle Illusion Disable automatic pIllusionRender call for oversized renders
  • Disable automatic pIllusionRender call for oversized renders
    Posted by Kevin Kipper on September 22, 2011 at 7:08 pm
    Hi Alan & forum members,
    It use to be possible to render whatever was viewed on the screen at the maximum resolution of the screen, but now if I scroll around on my stage and then try to render at 100% (part of my stage is offscreen) the pIllusionRender is called with it’s software (default) settings. What I really want is to use the hardware render to render what I see on my screen. Is there a way to bypass the call to pIllusionRender in this case?
    Kevin
    Alan Lorence replied 15 years ago 2 Members · 1 Reply
  • Alan Lorence
    September 22, 2011 at 7:15 pm
    No, it always tries to render the full stage extents. pIRender uses hardware acceleration too, so are you concerned about speed? Or do you really just want to render a portion of your frame for some reason?
    You may have to reduce your stage size and reposition things if you really want to do this.
    Maybe setting stage zoom to a lower setting?
    Alan.
    http://www.wondertouch.com
