Activity › Forums › Adobe Premiere Pro › Disable auto keyframes for audio effects
Posted by Sebastian Sander on September 17, 2013 at 6:35 pmHey.
Every time I put on an audio effect and adjust it, while listening to the audio, premiere is making auto keyframes. Anybody know how do I disable this?
Kind regards
SebastianMarius Ihlar replied 10 years, 4 months ago 5 Members · 5 Replies -
Ivan Myles
September 17, 2013 at 9:29 pmClick the stopwatch next to the parameter in the Effects panel prior to making any changes.
Sebastian Sander
September 18, 2013 at 6:50 amMaybe I wasn’t clear in my first post.
I very often use EQ and Dynamics on the audio tracks, and I use the “Custom setup”. When I do this i tweak the different settings to make the audio the way I want it. Sometimes I use some of the parameters, sometimes others. I do this while listening to the audio by looping it. The different effects makes a keyframe every time a parameter is changes. Then I have to put the time indicator at the last keyframe and delete them all.
And it doesn’t help to turn ON the stopwatch before making the changes. This will just make the process even worse. Because every time the time indicator goes back to that keyframe all the changes “reset”.
I didn’t have to do this either in CS6 or CS5.5.Isn’t there a way to just disable these auto keyframes?
Matthew Hoecker
December 23, 2014 at 6:13 pmSame problem here. Very annoying. How do I make it stop?
