Activity Forums Adobe After Effects Expressions Disable a Composition Programmatically
  • Disable a Composition Programmatically
    Posted by greg humphrey on March 29, 2024 at 1:48 am
    Is there a way to disable a Composition Programmatically?
    It can be done with layers, i.e. myLayer.enabled=false .
    But doesnt seem we can do the same thing on a comp, i.e. myComp.enabled=false.
    They both have the eyeball, you’d think this world work on both.
    Same goes with setting opacity on the comp, i.e. theComp.opacity=0; , that doesnt work either.
    Am I just not getting the syntax correct?
    Levi Borland replied 2 years, 5 months ago 3 Members · 3 Replies
  • Dan Ebberts
    March 29, 2024 at 3:41 am
    What eyeball are you talking about for comps? Comps as layers have layer eyeballs, but comps in the project bin don’t have eyeballs. If you’re talking about a comp layer, then to access it’s eyeball, you have to reference it as a layer.
  • greg humphrey
    March 29, 2024 at 3:33 pm
    Dan is the best!
    It’s the “Comps as layers have layer eyeballs” I was referring to. What I didnt realize was programmatically I can call a comp as a layer and access the properties that way.
    Something like this works.
    var theComp = app.project.item(i)
    for(var k=1; k<=theComp.numLayers; k++) {
    var theLayer = theComp.layer(k)
    if(theLayer.name==”myCompAsALayer”) {
    theLayer.enabled=false;
  • Levi Borland
    March 30, 2024 at 2:56 am
    You can also use expression controllers for this. Precomp the comp that you want to turn on and off. Then create an empty layer and apply a checkbox controller. Write an if/else expression on the precomp for opacity. If checkbox is checked, opacity 100, if unchecked – opacity 0.
    Something like this…
    if(thisComp.layer(“Adjustment Layer 1”).effect(“Checkbox Control”)(“Checkbox”)==0)0 else 100
