Activity Forums DaVinci Resolve dirt tool
  • dirt tool
    Posted by Darin Wooldridge on January 29, 2011 at 7:51 pm
    Been working with 2k 35mm dpx scans lately.
    Loving the ability to clean dirt but find it can be distractive. Seems it cleans the source frames. I have not found and undo function or an original frame saved that I can revert to if the fix is undesirable. It would be very nice it the fix was not committed until the render or you can revert back to the original if the fix is undesired. Am i missing something. Anyone have experience in this.
    NOTE: The comments above are strictly mine, and may not necessarily
    represent those of my employers.
    Darin Wooldridge
    Colorist / Technical Strategist
    818-653-3918-cell
    dwooldridge@mac.com
    check me out at https://www.facebook.com/pages/Davinci-Resolve-Colorist/117363011609028?ref=….
    Jacob Littleton replied 10 years, 1 month ago 5 Members · 13 Replies
  • 13 Replies
  • Muddy Wang
    January 30, 2011 at 7:32 am
    how about the film grain?do you use Revival?my 35mm scan dpx look grainy!
    thanks
  • Ola Haldor voll
    January 30, 2011 at 10:40 am
    I don’t have any experience with this myself, but during the demo in Oslo on thursday, someone from the audience asked about this.
    Dan Moran who held the demo, said it was “do this, click here, dust gone”, and that it would overwrite that exact frame to the source media. So I think that’s the way it works. If you’d like to undo that – I’m not really sure what to tell you. Take backup of the material before dust busting?
  • Darin Wooldridge
    January 30, 2011 at 5:24 pm
    I spoke to Dan yesterday and he agrees this should be fixed. Replacing the source dpx from a back up is how I fixed the issue. a simple undo would be great. Or perhapes commet the fix to the render. The lustre creates a original folder and saves them.
    Darin Wooldridge
    818-653-3918-cell
    dwooldridge@mac.com
  • Dwaine Maggart
    January 31, 2011 at 7:53 pm
    If you do a dirt fix on a frame, and want to UNDO it, you can press the PAGE UP key on the Mac keyboard. You can even save and recover the project, and go back to that frame, and the PAGE UP UNDO function still works. I’m not sure where the original frame info gets saved to make this happen. But it appears to be true (on the Mac Resolve at least) that as soon as you make a dirt fix, it’s applied immediately to the original source frame. When you do the PAGE UP UNDO, that is also immediately applied to the original source frame.
    Dwaine Maggart
    Blackmagic Design DaVinci Support
  • Darin Wooldridge
    January 31, 2011 at 10:31 pm
    Thanks Dwayne. I have one more. Sometime the dirt tool doesnt work. Unable to draw the box. I must be missing a step?
    Darin Wooldridge
    818-653-3918-cell
    dwooldridge@mac.com
  • Dwaine Maggart
    February 1, 2011 at 12:16 am
    You’ve selected the Dirt icon? If you right click the icon and change a Dirt parameter, does it work then?
    Dwaine Maggart
  • Darin Wooldridge
    February 1, 2011 at 4:18 pm
    I tested again this morning.
    Sometimes it works and sometimes it does not..
    Yes I select the dirt icon on the viewer page or color page, changing the parameters doesnt do anything.
    When I click on the screen to draw the box I get the following message. “refreshing screen.”
    Dpx frames were created by the resolve. I can put two sets of dpx frame in the same time line. One I can clean the other I cannot..
    Darin Wooldridge
    818-653-3918-cell
    dwooldridge@mac.com
  • Dwaine Maggart
    February 1, 2011 at 8:01 pm
    I don’t understand exactly what you mean by 2 sets of DPX frames in the same timeline?
    I’ve never seen the refreshing screen issue. Since it appears that it will modify the source frame as soon as you do anything, the problem might be related to write permissions on the source frame when it doesn’t work. Could you check that?
    Dwaine Maggart
  • Darin Wooldridge
    February 2, 2011 at 1:34 am
    One set of dpx frames was rendered via the resolve.. I can use the dirt tool on these frames.
    I have another set that was made with the resolve using convert format.
    Both are in the same session and same timeline.
    Permissions seem to be ok. Both sets of files are on the same storage.
    Darin Wooldridge
    818-653-3918-cell
    dwooldridge@mac.com
  • Dwaine Maggart
    February 2, 2011 at 1:38 am
    Can you send me a sample frame that doesn’t work?
    Dwaine Maggart
