Activity Forums VEGAS Pro directoryconverter.js errors
  • directoryconverter.js errors
    Posted by Todd Geer on January 21, 2009 at 8:23 pm
    I have this “directoryconverter.js” from some time way in the past. I’m trying to run it in V Pro 8 and it errors out. Any pointers?
    Error:
    C:\Program Files\Sony\Vegas Pro 8.0\Script Menu\Misc Scripts\Directoryconverter.js(180) : Deprecated: Please use GetInvalidPathChars or GetInvalidFileNameChars instead.
    The script:
    —start
    * This script renders media files found in an input directory using a
    * single render template and saves the results in an output
    * directory. To change the input directory, output directory, and
    * render template, edit the variables below.
    * NOTE!!! This script requires Vegas 4.0c.
    * Revision Date: May 01, 2003.
    import System;
    import System.Text;
    import System.IO;
    import System.Windows.Forms;
    import Sony.Vegas;
    // The inputDirectory variable specifies where the rendered files will
    // be created (do not include the trailing back-slash)
    var inputDirectory = “C:/TEMP/1”;
    // The outputDirectory variable specifies where the rendered files
    // will be created (do not include the trailing back-slash)
    var outputDirectory = “C:/TEMP/2”;
    // The rendererRegexp and templateRegexp variable are regular
    // expressions used to match renderer file type names and template
    // names.
    var rendererRegexp = /Windows Media Video V9/;
    var templateRegexp = /3 Mbps Video/;
    // The inputFileRegexp is used to filter the input files. Only those
    // whose file name matches using this regular expression will be
    // converted. The following will match all files the end with avi
    // (ignoring case):
    var inputFileRegexp = /.avi$/i;
    // This version will match all input files.
    //var inputFileRegexp = /.*/;
    // The overwriteExistingFiles variable determines whether or not it is
    // OK to overwrite files that may already exist whose name is the same
    // as ones created by running this script. For safety, the default is
    // false. Set the variable to true to allow overwrites.
    var overwriteExistingFiles = false;
    try {
    // make sure the output directory exists
    if (!Directory.Exists(inputDirectory))
    var msg = new StringBuilder(“The input directory (“);
    msg.Append(outputDirectory);
    msg.Append(“) does not exist.\n”);
    msg.Append(“Please edit the script to specify an existing directory.”);
    throw msg;
    if (!Directory.Exists(outputDirectory))
    var msg = new StringBuilder(“The output directory (“);
    throw msg;
    var renderer = FindRenderer(rendererRegexp);
    if (null == renderer) {
    throw “Failed to find renderer”;
    var renderTemplate = FindRenderTemplate(renderer, templateRegexp);
    if (null == renderTemplate) {
    throw “Failed to find render template”;
    var newExtension = renderer.FileExtension.substring(1);
    // create a new project with one video track and one audio track.
    var proj = new Project();
    var videoTrack = new VideoTrack();
    proj.Tracks.Add(videoTrack);
    var audioTrack = new AudioTrack();
    proj.Tracks.Add(audioTrack);
    // save the new project to the output directory
    //Vegas.SaveProject(Path.Combine(outputDirectory, “temp.veg”));
    // enumerate the files in the input directory
    var fileEnum = new Enumerator(Directory.GetFiles(inputDirectory));
    while (!fileEnum.atEnd()) {
    var inputFile = fileEnum.item();
    // skip files that don’t end with the right extension
    if (null == inputFile.match(inputFileRegexp)) {
    fileEnum.moveNext();
    continue;
    // skip files that are not valid media files.
    var media = new Media(inputFile);
    if (!media.IsValid()) {
    continue;
    var videoStream = media.Streams.GetItemByMediaType(MediaType.Video, 0);
    var audioStream = media.Streams.GetItemByMediaType(MediaType.Audio, 0);
    // if needed, add a video event and associate video stream
    if (null != videoStream) {
    var videoLength = videoStream.Length;
    var videoEvent = new VideoEvent(new Timecode(), videoLength);
    videoTrack.Events.Add(videoEvent);
    var videoTake = new Take(videoStream);
    videoEvent.Takes.Add(videoTake);
    // if needed, add a audio event and associate audio stream
    if (null != audioStream) {
    var audioLength = audioStream.Length;
    var audioEvent = new AudioEvent(new Timecode(), audioLength);
    audioTrack.Events.Add(audioEvent);
    var audioTake = new Take(audioStream);
    audioEvent.Takes.Add(audioTake);
    var outputFileName = Path.GetFileNameWithoutExtension(inputFile) + newExtension;
    var outputPath = Path.Combine(outputDirectory, outputFileName);
    var status = DoRender(outputPath, renderer, renderTemplate);
    if (status == RenderStatus.Canceled) {
    // may want have a dialog here allowing user to
    // continue with remaining files.
    break;
    } else if (status != RenderStatus.Complete) {
    throw “Failed on input file: ” + inputFile;
    // clean up the project.
    videoTrack.Events.Clear();
    audioTrack.Events.Clear();
    proj.MediaPool.Remove(inputFile);
    } catch (e) {
    if (!e.skipMessageBox)
    MessageBox.Show(e);
    // Perform the render. The Render method returns a member of the
    // RenderStatus enumeration which is, in turn, returned by this
    // function.
    function DoRender(fileName, rndr, rndrTemplate) {
    ValidateFileName(fileName);
    // make sure the file does not already exist
    if (!overwriteExistingFiles && File.Exists(fileName)) {
    throw “File already exists: ” + fileName;
    // perform the render. The Render method returns
    // a member of the RenderStatus enumeration. If
    // it is anything other than OK, exit the loops.
    //var status = Vegas.Render(fileName, rndrTemplate);
    return status;
    function ValidateFileName(fileName : System.String) {
    if (fileName.length > 260)
    throw “file name too long: ” + fileName;
    var illegalCharCount = Path.InvalidPathChars.Length;
    var i = 0;
    while (i < illegalCharCount) { if (0 <= fileName.IndexOf(Path.InvalidPathChars[i])) { throw "invalid file name: " + fileName; } i++; } } function FindRenderer(rendererRegExp : RegExp) : Renderer { var rendererEnum : Enumerator = new Enumerator(Vegas.Renderers); while (!rendererEnum.atEnd()) { var renderer : Renderer = Renderer(rendererEnum.item()); if (null != renderer.FileTypeName.match(rendererRegExp)) { return renderer; } rendererEnum.moveNext(); } return null; } function FindRenderTemplate(renderer : Renderer, templateRegExp : RegExp) : RenderTemplate { var templateEnum : Enumerator = new Enumerator(renderer.Templates); while (!templateEnum.atEnd()) { var renderTemplate : RenderTemplate = RenderTemplate(templateEnum.item()); if (null != renderTemplate.Name.match(templateRegExp)) { return renderTemplate; } templateEnum.moveNext(); } return null; } ---end
    Todd Geer replied 17 years, 7 months ago 4 Members · 5 Replies
  • Steve Rhoden
    January 22, 2009 at 3:12 am
    I have no idea what all that is saying or for what purpose you
    would need such a script…..otherwise i see NOTE!!! This script requires Vegas 4.0c. then clearly it is not compatible with
    Vegas pro 8.
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Portfolio at:
    http://www.youtube.com/hentys
  • Todd Geer
    January 22, 2009 at 3:38 am
    Correct, it appears to have been written when V4 was the current version, so I’m sure the developer put that in as a disclaimer/clarifier.
    Someone out there who knows js should recognize the error and know what it’s talking about, and THAT’s what I’m looking for. Else I would be able to solve it myself.
  • Gilles Pialat
    January 22, 2009 at 8:10 am
    Proxy Stream can do the same job:
    https://sony.vegas.1.free.fr/
  • John Rofrano
    January 22, 2009 at 11:44 am
    That script is from the Sony Script SDK. Just download the Script SDK for Vegas Pro 8.0 from the Sony site and you’ll have the latest version.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Todd Geer
    January 22, 2009 at 7:38 pm
    Thanks, Gilles! Just what I was looking for!
